Wheel Bearing
MARKY46
Hi folks.
Looking for a bit of advice??
I am going to have to replace the front driver's side wheel bearing, due to the fact it is knackered, on my 00' plate IS200se and I'm looking for all advice and tips possible with regards to doing this.
Is it quite a straight forward job or are there any dangers I need to be aware of?? I'm hoping its not too difficult but if there is anyone out there who has encountered any problems can you let me know please??
I know I have to get the hub off the car, which seems quite straight forward enough, but then what do I need to do??
Any help would be much appreciated.
Thanks folks.....
Hi folks.
Thanks folks.....
Are you going to go from the caliper side or the back side, i just replaced my ABS ring and i took the back off i think the barings are next to that.
All you do is turn the wheel full one way then you can pop the back of the hub off. then unscrew the big bolt pop out the abs ring and then the bearings are after that.
Im sure some one else will be along to correct or add to what ive said.
Good luck matey
people have replied in your other post with exactly the same question - it makes it easier for all those involved ( including you) if you just make one post, so al the replies are in one place.
This topic is now closed to further replies.
