Peep's With A Decat'ed System
Robin H
well my plan for a full decat system well went a bit wrong to day :duh: :duh:
as the template the had been used for the decat would have meant doing a bit of a cut and shut which I wouldn't want to do, it's a bit :blush: at the mo, also I want to have a full stainless system
so my Q to you is:
where did you get your decat centre section from or what did you do ????
I got the mid pipe with resonator and the exhaust back box from a regular is200
(1) cut the flange off the back box and throw the back box away :D
(2) cut the mid pipe in 2 holding on to the piece with the resonator.
(3) weld a straight pipe from the resonator to the flange fom the back box and now you have a perfect fit altezza de-cat pipe.
I noticed an excellent gain from 1 -4k rpm and it got rid of the annoying flat spot @3500rpm.
Excellent mod for the cost.
so my Q to you is:
Prolex did my cat section at the same time as the manifold - top quality kit and gave a 20rwhp increase!
thank for the response guys
well a new manifold just gone on today :D so there be no probs there
so the is and rs have the same centre section then
may have to do a bit of investigating with the link that you posted cyborgguy
thanks very much
What manifold did you put on and have you tested it out yet?
thanks very much
http://www.exhaustuk.co.uk/home.htm another link for you.
Daza W used them, around £100 and it allows u to re-fit intime for MOT.
Gotta get mine done pretty soon too!
Same place that I used after Daz put me on to them. Very good, quick and cheap too. One of my mates also had a complete system made by these guys for his Supra and he's also a very happy bunny
