Anyone Know Japan Language For Sat Nav Hidden Menu
After to go on an other is forum. I have found a tip to have access to an hidden menu on sat nav.
Here, the pictures of the first hidden menu.
But there is a problem because behind the first hidden menu there is a second one.
Look :
Anyone can translate the menu for me.
To access the hidden menu :
1. Apply the parking brake
2. Insert key to ACC position
3. Hit the MAP button to power up to the first screen that prompts for english or french language..
4. While on the english/french screen hold down the NAV controls INFO button while you TURN your steering wheel TAIL LIGHT SWITCH on and off 3 times, OFF,ON,OFF,ON,OFF,ON,OFF.
To access the second one. You do the same thing (press info and switch on, off 3 times) during the first hidden menu
Is it possible that tip works only for DVD sat nav
This has been posted on this forum somewhere before ........... and I believe it was also translated.
You can also check the speed you are doing, according to the GPS sensor ..............
  • 2 months later...
