Rear Seats Removal
Ellz
Pull at front of seat base (bit you sit on closest to front seat) and this should lift up and pull away and out of car.
You will then find 4 x 12mm bolts to remove at base of seat (2 each side).
detach seatbelts and head rests from seat.
Then push upwards untill seat unclips and pulls away
helps if there are two of you
