Look What Going In Tomro
Looks good matey, Hope your pleased with the finished product.... the only vibrations i seem to notice is the number plate :lol: but thats only noticeable when you are standing outside, but you learn to live with it. good stuff mate and enjoy :D
Pretty pleased with it, the only thing is, the bloomin Battery keeps running down soooooooooooooo low that i cant unlock the thing in the morning, i havent wired up my memory wire to my headunit yet, is this the problem, as sometime when i turn off the car the headunit stays on ??????
Cheers
as scarface mentioned you have wired the positive from the headunit onto the constant positive on the car...
Wire your positive up to the other postive feed which will be the power when the ignition is turned and wire your memory wire onto the constant positive feed(which you have connected already).. this will also save your settings if you have made any :)
Cheers
Ahhh so the mermory wire just gets connect in with the constant, seems simply now lolol
Cheers
