Mk2 Headlights
rocky v 300
Hi all,
long time no post I know, had a little accident one icy evening and landed straight in to a roandabout at about 80mph!!!
as you can imagine the front driver side was completly trashed and the rear wheel moved back as well!
Its been in the garage now for 7 weeks and finally gona get it back this week after haveing much of the underneath of the car replaced (exept for the ARS) which they are going to investigate, ill make sure of it!!!
Any way i just wanted to find out how you can manually adjust the headlight as mine focus too near to the car, its a night mare on the motorway in the middle of the night. I tried to turn a nut with an 8ml head directly behind the light and it did make a slight difference but then a light came up on the dash (the headlight sign with an arrow pointng up and one pointing down) so i changed it back.
Please help.
Rocky
They are self-levelling theres nothing to adjust them with other than that nut your talking about.
My light (the one you got!) has recently come on and I can actually see a damn sight better at night so mines staying as is.
I'll take a look this weekend and see if theres something than can be adjusted!
Gaz.
