Wiper Sprayers
It's probably just blocked.....just try using a needle or a pin to wiggle around in the holes :winky:
Otherwise you have to go messing around removing part of the soundproofing under the bonnet :crybaby:
Unfortunately the needle snapped off in it last year, I had to drill it out with a .8mm drill bit.
It has worked till now, but I think there must still be a piece of the needle in it.
Its the drivers side so thought I would swap them around, but it looks like you need 8 inch fingers that have at least five bends to get to them.
You can carefully slide something like a credit card under the front or back edge and it should easy out, try a search for triple jet washers there was an explaination on that thread
Thought there was a nut securing it from the underside?
Not on mine, I've changed them twice and I didn't take the soundproofing off. If I can find them I've got a set of black twin jets if you need to replace one
Cheers m8
Let me know if you find them and I will pm you my address.
Yep, same for me, works very well with a LOC Gold card :winky:
