Knocking/creaking When Turning And Breaking
vinokirk
I had this problem on mine, so i replaced the front discs/pads and it went away for about 2 weeks and now its back! *** damn it it really annoying! Does anyone know why it would come back after just 2 weeks?
Changing the pads/discs wont fix it,its the bushes etc,the warmer drier weather will give you these symptoms because everything dries out,suspension parts could also be worn.Might be worth greasing up the moving parts,on the old cars they had grease nipples that you could pump grease into to keep things from getting dry.
