Cam Timing
Right continuing the theme for the mods etc for the near future one of the next ones will be a set of adjustable cam gears. The idea is i am going to advance my timing slightly (4deg) to try and bring some more power down at lower revs. However this will be a first for me i have never played with cam timings before and i definately don't want it to be a hit and miss operation, especially with a big miss being a bent valve etc.
The basic plan will be to set pot 1 to TDC then change the OEM cams for adjustable ones, hopefully this will give me a good starting point after the change though i am in head scratching country. I intend to advance intake and exhaust by 4 deg.
SO any top tips or screams of horror would be appreciated especially if you have prior experience and know some arcane cam tuning black art
Austin
Austin
bump
anyone :unsure:
There does not seem to be much modding info available for us poor Mk1 GS owners. I would have a word with Mark at TDI or perhaps PM big Matt or dangerous-brain (usually posts in the Aristo section) or failing that try one of the many Supra performance bulletin boards.
anyone :unsure:
looked at the supra boards unfortunately alot of turbos there who go for the cams too so it would change the amont of advance retard from what i gleaned factory settings are the best all round but seeing as i don't do 145mph very often i am willing to sacrifice my top end.
The main concern is going the wrong way and buggring the engine really i have grasped the theory but its the practical that worries me
