Blue/white Smoke Cold Start -- Help!
Felix
Hi Guys,
I imported a 1998 Harrier 3.0 last week, no service history; it has done 58K (miles). The car drives well.
For two days, it blows quite bit white/blue smoke in the morning. Smoke lasts 1 and half mins, and then nice steam comes out.
No smoke when driving around.
I have booked a 60K service in my local dealer, but I want to know what is the problem?
Any one could help???
Many thanks
Felix
Hi and Welcome to the LOC :)
Thats a fair bit of smoke from the picture you posted.If thats starting the engine up from cold id say its the valve stem rubbers that are worn,when you switch the engine off and leave it over time,say overnight all the engine oil is running down the valve stems on to the piston rings,then when you start the engine up for the first time thats the oil burning off the pistons giving you the smoke.Id keep a eye on the engine oil level in the morning before you start it,just to get a feel for how much oil it is using..
Replacing the valve stem rubbers should fix the problem,at a guess id say it would cost a couple of hundred quid tops for a garage to replace the seals...
:excl: Keep a eye on the oil level until you have it fixed ;)
Let use know how you get on regards to having it fix..
Good Luck
Chips.
Mine does something similar but not as bad as yours though based on the picc, on mine, it's the valve collets that have gone.
Takes a few minutes for any white/blue mist to disappear and then nothing after this, but mostly in the cold rather than in warm weather
BR
Paul
Many thanks for the replays guys!
I thought the same thing, so I have called another 2 dealers to see how much to replace the seals, guess what, they said it is 2 days work, so we are taking about £90 x 16 hours = 1440.
As I said I have booked a 60K service on Friday, I will let them come with some suggestions about the problem. See what they say.
I will keep you guys updated.
Felix
P.S. you don’t think it is the rings, do you?
Does anyone know any places good around Birmingham area which I can trust?
I did have a quote for £700 from a "cowboy", I just did not like the way he talks.
Many thanks
Felix
Agree with Chips sounds like valve stem oil seals. Rings usually give out smoke on the overrun.
Some engines can have the seal replaced with the head on if you have the correct special tool to hold the valve in place as you remove the springs to get at the seal. Without that you have to take the head off so 2 days is about right, £90/hr seems steep though. Your "cowboy" at £45/hr less parts seems about right on cost.
Hi Guys,
I got the car back, it was not too bad, they did the 60K service, didn't find too much problems.
The only thing worth to mention is the "N/S inner + outer drive shaft boots split" I may have to get a new drive shaft. Could anyone tell me how much are we talking about here???
About the smoke, they said it might be the "PCV valve". Any idea how much to fix it???
Many thanks
Felix
Many thanks Paul,
The PCV Valve on the Harrier is located on the back of the engine, and it is not as easy as the LS 400 shows. It needs to remove quite few parts to get there. It only costs £5 in parts, but I don't really think it is the problem.
As you can see the smoke is quite lot, valve stem seals most likely to be the problem.
I will have someone whom from an engine specialist to look at the car tomorrow, I will keep you guys updated.
BTY, do I have to remove the head to change the valve stem seals on this one????
Someone said I could use the low air pressure to hold the valves in place while changing the seals without removing the head; does this apply to this engine????
Many thanks
Felix
If you can get hold off a valve stem replacer tool then no, this locks onto the valves themselfs, and keep the valves up so that you can remove the collets for replacement, make life alot easier.
As for the low pressure, not sure but if your stems are coated with coke, then the pressure would not work
Hello guys,
Many thanks for all of your replies!
I have drawn a conclusion that is I need to replace the valve stams seals. After I tried many different things to fix it, the mechanical fix is the only way I can really fix the problem.
I have ordered the parts from my local dealership for £187 (Head Gasket Set), they will deliver the parts on Friday. If I get it from USA, it costs £160 but takes 10-day delivery.
I got the “explore view” of the engine head, and the valve replacement tool, and my good old friend whom has been working for Ford for 30 years comes to help, he is doing this kind of work day in day out all the time.
Fingers crossed, Hope everything goes OK this weekend.
I will keep your guys up to date later….
Felix
P.S. this there anything your guys want to tell me to watch out???
Sorry for my slow follow up.
Due to family event last two weekends, I was not able to do any thing to the car; I have booked this week off to finish off my second garage at the back of the garden.
Hopefully I can start the job today or tomorrow.
Will keep you guys up to date...
Felix
All done,
it takes lots more work than I throught.
I had to take the heads off, which I am glad I did that, sent them to steam clearned.
there is only one thing I want to tell you guys, a manual is very important, I got it from eBay, without the manual I would be in deep s**t.... It is so good.
here is the link: http://cgi.ebay.co.uk/Lexus-RX300-Harrier-...1QQcmdZViewItem
there are some pic for you to share...
Cam over off
Heads off
Engine bay with one head off
Steam clearned engine heads
sorry for the low res, I had to take it with my phone.
More to come
Felix
looking good so far, your well on your way to fixing the problem once and for all.
Good Job Felix, always helpful when you have someone that knows a thing or 2 about these
Thanks for the update
Thanks for the update.
Id get some oil...WD40 or engine oil on the parts youve steam cleaned or before you know they will start to show signs of rust :shifty:
Keep up the Good Work.
What state were the valve stem rubbers when you first took the head off?
Was the seals hard or breaking up?.
Chips..
Chips..
Guess what, there are only 2 seals became bit hearder than others, and only those bruning oil, you can tell from the states of the plugs, can you?
I got lots of pictures, I will get them all posted next week.
thanks
Felix
