Interiors
dazw30
I've had the back seats out - very easy - the bench pops upward with a good tug, and then there are 3 bolts underneath holding the back in place.
5 minute job once you know what your doing.
Ian
Anyone done the carpets :question: and everything else :question:
I have.
Only thing i haven't taken out is the Dash. I've taken parts of it off but i think Mat is one of the few who has stripped and assembled the Dash...
Thanks everyone :winky: and anyone know how to wire them in
TIA
Daz
This *might* be applicable to your combination... (and make sense)
Pin designation refer to a 6 pin plug - only have info for D/S plug..
Power seat
White thick (pin1) - constant power (30A fuse)
White/black thick (pin2) - ground
(All the switching is done in the seat)
Seatbelt warning switch
D/S - Pink/Green (pin4)
P/S - Pink/Black
Switch to the same ground as power seat supply ground(pin2)
Seat heater
D/S - Red/Blue (pin3)
P/S - Red/Green
These wires take switched positive from 15A fuse, grounded through power seat supply ground (pin2)
Hopefully this will give you something to go on...
cheers all
got them in on sunday (thanks to mr singh)wire's were spot on heaters work to just had to run a 15amp red/blue wire from drivers side switch to under the seat (was already there on passengers side)and he hey! warm butt,and looks well to got the interior from an 04 is200 styling chrome speaker covers the lot
thanks again
Daz
:D :D
Superb!!
My heated seat doesn't work lol
So did u run from the harness at the back of the dash (where the heater swtichs are) a seperated wire spliced into the red/blue wire to the red/blue wire on the seat?
