Wednesday`s Joke
Bazza
The world's foremost authority on wasps is walking down the street when
he sees a record in the window of a charity shop "Wasp noises from
around the world". Intrigued, he goes into the shop and asks if he
can listen to it.
"Certainly," says the shop assistant and pops it onto his turntable.
After listening to the first track for a while, the world's foremost
authority on wasps is a bit confused.
"I don't recognize any of these noises, and I'm the world's foremost
authority on wasps! Can you play the next track please?"
The assistant obliges and skips the needle onto the next track after a
while, the world's foremost authority on wasps is still confused "No,
I still don't recognize any of these wasps. Can you try the next track?"
The assistant skips the needle on, and the world's foremost authority on
wasps listens for a little while longer before shaking his head.
"It's no good. I just don't recognize any of these wasps"
The assistant peers at the label of the record and says...
Oh I'm terribly sorry. I had it on the bee side"
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
