Gs300 Maintenance Manual Oil Leaks
Hi!
I have just discovered an annnoying oil leak to the back of the engine of my GS300. Having spent some time having a good look it appears to be leaking from the rear of the cam covers or maybe the cylinder head. Its not a lot but very annoying when it leaves a blob of oil on the drive after filing up the plastic cover underneath. I could take it to a garage but I am sick of getting ripped off, especially when I have the toolong myself.
Firstly has anyone else had problems with oil leaks?
Secondly, where can I get a copy of a GS300 maintenance manual?
Help please! :crybaby:
Regards
Mike
i had a gs come in with a leak at the back of the engine ended to be the rear main oil seal so the bloke did not have the money to do it as its a gearbox out job so i think he put the stop oil leak stuff in it and stopped it but i never tell people to do it as you never know what it can do
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
