Water In Footwell
davyc
I have water coming into the passenger footwell from somewhere on the door side, I'm pretty sure its rainwater, anyone any ideas ?? thanks
Hi and Welcome to LOC :)
Could be any of these....
As above a poor seal around the windscreen.
Blocked water drain way from the sunroof.
Blocked drain way along the bottom of the door.
Floor drain rubber bush missing.
Or at the Very worst the heater matrix :crybaby:
Posting more info might help us narrow it down abit more.
Chips..
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
