How To Change The Cambelt?
10 years of Lexus design: from spindle grille to spindle body
On both models, the spindle generates lines that flow back from the front of the car through the bonnet and headlamp units to create a strong and distinctive frontal appearance, reinforcing the brand-defining ambitions of the original concept.-
- 0 replies
Lexus joins the UK’s Motability Scheme with the new UX 250h F Sport Design
From this week, people with mobility needs will be able to access a Lexus vehicle through the UK’s Motability Scheme-
- 0 replies
All-New Lexus RX to star at the Venice International Film Festival
- 0 replies
The all-new Lexus RZ: powerful design rooted in electrified performance
Lexus maintains its status as a design innovator in creating a radical look for its all-new, all-electric RZ that directly interprets the SUV’s power and performance-
- 0 replies
Lexus guide to interesting EV charging locations off the motorway
With the Great British holiday getaway on the horizon, drivers of BEVs (battery electric vehicles) will be considering where to recharge on their journey. While motorway service stations are an obvious choice, Lexus has researched some more interesting alternative locations
- 0 replies
