Clutch Cable
GWilso
Hi guys some of you may have seen I recently posted topics about fighting with second gear on occasions? and some have said possibly linked to the clutch on its way out
Now just recenlty (yesturday) when change gear I can hear the movment of the clutch cable is this just a case of needing greasing or..............?
Unfortunatly I can't just go and get a new clutch under warrenty (non Lexus) as they won't replace anything if it's not broken :angry:
oh and the warrenty runs out in 2months so if any of you drive past a tall angry bloke stamping up and down on the clutch of a green IS200 oustide a mechanical garage then don't worry only me :P
Although it probably would be less hassle to renew the warrenty :D
Many Thanks
Mine is also a bit creaky as is a few others that i test drove, seems to be an IS200 thing.
When stationary i can hear a kind of rattling sound, when i push the clutch pedal it stops...this was diagnosed a while ago by 'CHIPS' as something like a bearing, nothing to really worry about.
Something that gets replaced when the clutch is changed.
A few people have this issue with there clutch.
Still don't know about the gear change thing...
i get exactly the same symptoms, took it to my local garage a couple of weeks back and they said the same, that its nothing to worry about.
only happens occasionally though.
