Spark Plugs, When Do They Need Changing?
Leeky
Hey guys, my car has just hit 67k miles and i was wondering if its about time i got new sparks?
Whats the life on the stock ones and should i go Iridiums or just Platinum?
Cheers
The Spark plugs are a job on my list to change in the near future on my car,im not sure as to the service interval though.
:excl: The coil packs are very fragile if they`ve been on the car for a long time and are easy to damage.
There about £85 each :o and theres one for each sparkplug.Thats why ive left the job for now.
Theres a guy on another forum im on whos just repaired his coil packs as they were cracked,so there is another option rather than replace them with new ones if there not to badly damaged.
Hope thats some help to you.
Chips..
I think they're Platinums as standard, and should be changed every 60k IIRC.
You can now get Iridiums for around £40 for 6, so I'd go for them (and will be ordering some early next week)
Denso IK22's if your BPU, IK24's if more
NGK also do Iridiums
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
