Is200 Transmission
I am looking to upgrade my transmision for some stronger parts because i will eventually be running more power.
I was wondering if any of the techies new if the diff and drive shafts from a gs300 or ls400/430 perhaps would be a straight fit to the IS200??? I know the IS300 diff and shafts are stronger and are a straight fit but they are obviously harder to find.
Any info is appreciated :blush:
well im still running the is200 torsen diff.......and its had a hammering
Did you just fit the getrag 6 speed to it then mate? Obviously with some modding for it to fit?
well the prop is custom, so its that that joins the two parts
