Leather Seat Restorer / Cleaner
Whoosh
Can anyone recommend a good leather seat restorer / cleaner?
I have looked on the Car Care section where they give advice on how to do it but not what to use.
I would like one the feeds the leather and as well as cleans it apparently from what I have read.
2. Initial conditioning - for the initial conditioning of uncoated leather, and/or if you are cleaning it for the first time use a Leather Rejuvenator. (http://www.Leatherique.com) [use Zaino Z-10 Leather in a bottle on coated leather] paying particular attention to area that are exposed to the most UV radiation, i.e. backs of headrests, seat shoulders, and then apply to the rest of the seating surfaces starting at he top and working your way down.
Allow the product to be absorbed into the hides for several hours on a sunny day, or overnight. Warmth makes the leather fibres pores open allowing the proteins and collagens to be absorbed readily. Park the car in direct sunlight, cover seats with black plastic trash bags, and roll up the windows to create a steam room to allow the Rejuvenator to fully penetrate into the hides.
2a. Conditioning- recommend a preventative maintenance routine three to four times a year, once prior to the winter season to prevent cold temperatures cracking the leather, and once before the heat of the summer to prevent deterioration and shrinkage by heat, which result in continued cracking of leather. In addition to regular cleaning, leather requires replacement of natural oils; Collagen-based products like Leatherique restore the lost moisture and maintain its natural flexibility. The smell of leather comes from oils evaporating out of the hide.
Conditioners are for leather which is porous, vinyl is not, do not use a vinyl product as a conditioner on leather as vinyl requires much stronger cleaning agents than leather and above all try to avoid raw silicone oil based products, as the silicone oil will dissolve the leather's natural oils and tend to make the leather sticky, silicone oils also have a very high electrostatic (static) attraction to dust and dirt particle.
