Auto-climate Stuck On Re-circulate
I have a new shape GS300, 12 months old but new to me 2 months ago. Only 4k on the clock
The climate control seems to have stopped switching from circulate when stationary and external on moving, to recirculate all the time. I have tried setting the sensitivity of the filtering to minumum. No change. Has anyone had this happen to their GS?
TudorDoc
TudorDoc
Could it be the temperature you have it set to relative to the outside temperature... in this hot weather, my re-circ is switching on more and more often by itself to get the temperature in the car down.
TudorDoc
Had the car into Lexus to get dash rattles fixed. Turns out the sensor for the air-con needed replacing
TudorDoc
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
