Steel Wheels
Hi does anyone know wot size steel wheels will fit on an is200 sport on the back? Gettin 2 wheels refurbed and thort if i can get some wheels 2 run on for a week it saves taking it off the road! Any ideas of what cars wheels will fit on it?
Thanks Dean
Thanks Dean
16"
17"
18"
5 stud
PCD 114
offset 38 to 45
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
