Is 200 Se Spark Plugs
Aviator
Would like to thank who ever it was for suggesting replacing Plugs on my I200SE to Denso IK20, noticable difference on pick up! Strange, plugs removed (original) were NGK, and not Denso. On a seperate note, is there an easy way to get to the Oil filter, want to change my oil every 6 months, had to get local garage to do it, as my small ramps in the driveway were insufficient. Fram 3614 will work on UK spec IS200, but did not notice any valve inside, any thoughts? :blink::blink:
  • 4 weeks later...
Hi
May i ask where can you get Denso IK20 spark plugs from and how much as wish to change mine.?
many thanks
Cheapest is a guy off ebay. Ships from USA. Very quick delivery and about £36 all in :D
Hi
many thanks
I only paid marginally more for the IK22 from USA ebay. Good delivery times to!
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
