Led "pulse" Brake Light Bulbs
Ok i have recieved this item and installed this item correctly i think
No lights on the Dash now (did have at first)
However they do not flash only do the standard brake?
Any Help
Cheers
Andrew
replied in the main thread
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
