Autoleads Pc9-411 Any Ideas?
Firstly i'll say hi all! I have be reliably informed by Sextons of Cardiff that the autoleads iso adapter PC9-411 will fit my SE without the need to bypass the amp does anyone know if this is true? the lead is actually for an mr2 but they say it will fit!
Welcome to LOC... :D
Don't know if it would work as it's supposed to be for an 94-00 MR2 only...
But if it does work then there will be alot of interested peeps on here...
Can you post up a link for this please?
This should be interesting, good luck. It'll be amazing if it works.
I know Adie has used an autoleads adapter and it worked as he has the basic S model, ie. no amp.
I done the same on my Tezza...... glad i had the basic system
I've got the sport so I'm screwed at the moment...if this works I'll owe you a few drinks as a thanks :winky:
The autoleads part no. I used was PC2-17-4. This is a standard Toyota ISO connector for the S model. It will NOT fit the sport or SE model.
With regards your part no. mate I wasn't aware that there was one you could buy for the SE and Sport. Which is why Fargo had some made up.
If it does work mate. Make sure you post on here as it will help out LOADS of people that have been after the same thing :winky:
Sorry guys but there is no aftermarket direct plug in lead!
Which is why Fargo had a load of custom made ISO connectors :winky:
IS 200 S uses the autoleads PC2-17-4 :)
Oh hang on I've already mentioned this ;)
Edited by ad77
