I have the 2 memory seat buttons but either they don't work or I'm not seting them correctly... how do you set them?
Read something on the US forum about not pressing the brake pedal, but not sure what else.
:duh:
Turn ignition on, adjust seat etc., then press SET and 1 , you should hear a beep.
Only works with ign. on, not when engine running :winky:
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
