Powergain Module
Hey guys found this on e-bay
http://cgi.ebay.co.uk/LEXUS-IS200-IS-200-3...1QQcmdZViewItem
Its suppost to increase BHP by 20
anyone tried these? do they work? :huh: bit sceptical here
I'm guessing it's just like the thing I asked about last week, apparently there pretty useless. But i'm sure someone else can confirm this later for you.
It's a resistor that changes the voltage from the temp sensor to make the ECU think the air is colder than it is, this in theory makes it inject more fuel :duh:
Con and avoid
Yes mate, they are a rip off. Do no good at all :) I think there should be a sticky put up for this as it gets asked once or twice a week. :duh:
Well, I did once upon a time put it in the FAQ section ....... but Steve decided that we didn't need it ....... oh well
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
