Locking Wheel Nuts
the_wiley
Just tried to undo one of my nuts / bolts to find my factory wheel brace does not go into the hole to undo the nut / bolt. Where can I get a wheel brace to fit ?
I think you'll find that a 17mm socket will fit :D
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
