Squeaky Doors
Niraj
This is a nice and simple one but thought i'd post up just to add to the guide.
All 4 of my doors started squeaking / creaking recently, not sure if it was coincidence or the fact that i cleaned the car inside and out.
Anyway, the solution is simple:
Open the doors wide open, and find the hinge about half way down connected to the car.
Squirt 2 shots of spray grease or a couple drops of lube on the pin, and swing the door a few times for the lube to get around the entire hinge.
Voila :D noise all gone. B)
The rear passanger door on mine is quite bad for creaking and I clean inside the door near the hinges too, thanks for the info on that one. :D
