Heat
Is anyone noticing any difference in their cars with the mad heat that's out there at the moment? It doesn't help that when it's so hot you need the air con on and the temperatures get even higher under the bonnet.
In my motor (not a Lexus) I'm noticing the gearchange getting a little bit harder when stuck in traffic, like the clutch hydraulics are suffering a bit. Plus the odd time the car's felt slow off the mark, definitely the "heat soak" effect!
My car is definately not as pokier in the heat. Also everything gets sooo hot in the car especially under the bonnet.
Maybe vented bonnet as a future mod :duh:
running mine the other day (outside temp said 38, london), I was actually quite impressed by how well it pulled! :D :D :D
