Spark Plug Gap?
andyred
hi friends i own GS 300 twin turbo jap import running in india,the standard iridium spark plug in NGK isBKR 6 E =WITHA GAP IS =0.044MM ..I WANT TO USE HIGHER HEAT RANGE OWING TO LOCAL AMBIENT TEMPERATURE HENCE PLANNING TO USE BKR 7 E OF NGK/ DENSO IR-22. :question: DO I HAVE TO RESET THE PLUG GAP TO 0.044MM OR LEAVE IT TO STANDARD OF 0.032MM?( THIS PLUG GAP IS FACTORY SET AT 0.032MM) can any one help please bye
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
