Master Brake Cylinder Failure On Ls400 1996
murph
Hi all,
I have a 1996 LS400 that has brocken down with brake fluid leaking from the master cylinder to the servo and wondered if anyone could help with the following:
- can the master cylinder be rebuilt?
- where can I buy a kit from?
- if it can't be rebuilt then where can I buy an exchage unit?
or do I have to buy new from the main dealer?
Many thanks
Murph
Hi all,
Many thanks
Murph
Just found out from Lexus Twikenham that they do infact sell a service kit priced £86.91 plus vat and a new unit is £223.76 plus vat so will be discussing with my engineer if rebuild is a reasonable option.
Murph
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
