Hey guys
need help!!!!!!
ok my 500 pound ( 1993 ls 400) project failed on its mot due to two things fog lights and belt buckle!!! my fogs were working the other week when i tested them but now they are not? ive tested the switch - it has 4 cables coming into the switch one live and the other 3 are not so i tried powering up the other three cables and one when pop. i blew a fuse - changed the fuse and now the headlights arent working the main beams not the dipped
please can someone help me as im working blind with no manual just the loc for help... thank you to those who can advise
matthew
You more than likely read this yourself,theres fuses under the bonnet and more fuses in the drivers footwell.
It might also be worth checking any relays,id also try looking through the LS section of the USA site as there could be more info,if you dont find the info you need join the US forum and ask them they seem to have most if not all the answers because of the vast number of LS in the states..
USA link..
http://us.lexusownersclub.com/forums/
Hope thats of some help to you.
Chips..
