Fuel Injectors
snope
Beside aftermarket japanese brand fuel injectors, has anyone tried upsize stock injectors from other car makes on our altezza? I am looking at using EVO 8 MR injectors but don't know whether will it fit nicely on our ride..
Pls advise.
Cheers
The connectors won't be the same, other than that you need to look out for what type the injector tip is And the size as a longer or shorter injector would mean correctly spacing the rail for a firm seal. There are nylon spacers used on our rails which i guess could be modified for slightly smaller height or machine new ones for taller type.
http://www.sdsefi.com/injectors.htm
Ours uses Disc type. I have some Blitz 525cc injectors which i got pretty cheap, search on eBay you could get lucky! And save a whole heap of hassle!
Ours uses Disc type. I have some Blitz 525cc injectors which i got pretty cheap, search on ebay you could get lucky! And save a whole heap of hassle!
Exactly.. that's what I was warned by friends here that there's a lot of details to look at in order to find the right injectors... Those Blitz ones that u have gotten off eBay are quoted specifically for altezza? I saw all kinds of injectors on eBay but they did not mentioned specific car type..
cheers
cheers
Somehow I think I am one of those friends of yours :P
Blitz Side feed 525cc hi resistance injector 0.99ms JPY10,000 each ;)
cheers
I got mine from this seller - http://stores.ebay.co.uk/JAP-PARTS-SPECIALIST-com
Contact him as he's pretty good for injectors.
