Sxe10 "fan" Ecupin Location Needed, Help !
*A1*
Hello
does anybody knows what is "FAN" pin in SXE10 ecu, I have -98 RS200 manual engine in my car, but can´t get electric fan working. And if someone knows what pin it is, then will it give 9-14 volts or ground (-), when warmed up, and in what temperature about?
It would help me a lot. If you help me, I can tell what kind of powerfigures my car gives with my new Apexi power FC :winky: But can´t dynoed it without fan :crybaby: (ok, I have manual switch in fan, but it´s crappy)
i take it you have checked the coolant sensors
Haven´t otherwise that apexi commander shows sensors giving values what are different cold/warm and commander shows watertemperature correctly. So I think that those works.
My car is -72 toyota carina, which have RS200 engine, transmission, brakes etc. I hunted wiring diagrams over year, now otherwise it looks working nice. My diagrams, which came from australia, shows that connector E pin number 4 should give 9-14 Volts, when engine temperature is high. Mayby I should warmed it more, in 95 degrees celsius nothing happened in pin "E4"
