Lowering Springs Buying Help!
There are so many manufacturers when it comes to lowering springs.
Can someone do a list starting at 1 going down....
1 is the best and gets less crapper when going down.
cheers,
There's a thread on this very page mate by Bulldog about lowering springs :winky:
i notice the eibach springs lower by 1inch (25mm) in USA for the IS300.
Why do people say it lowers by 30mm when its actual 25mm?
1" = 25.45mm
They round it up so it sounds like a bigger drop than it actually is....
It is in fact 25mm
1" = 25.45mm
It is in fact 25mm
1" = 25.4mm that rounded up would be 26mm not 30mm, and as Eibach are this side of the pond 30mm would be 30mm and nothing to do with inches.
The septics will round down 30mm to 1"as there is no conventional fraction of an inch that matches 5mm :D
Doesn't the IS300 have a different spring compression or something anyway to the IS 200? There is a thread on here about this somewhere. With the difference with fitting IS200 springs onto the IS300
1" = 25.45mm
It is in fact 25mm
Let's call it "marketing license" then....
Yes, I have IS200 Eibach's on my IS3 ........ and it sits lower than 30mm :)
