roll down rear windows,
single press arm the vehicle
wait for alarm indicator to start flashing (approx 30 seconds)
stick your hand in the back and wave it around... (not the hand holding the keys, incase you drop them in, :lol:)
listen to the siren and horns blare....
single press disarm the vehicle to disable siren :D
did it work?
Another way, which is easy, is pull the bonnet catch in the car to pop that up, then shut the door, lock the car using the button, and then open the bonnet using the manual latch - that's how I do it!
I think the easiest way is to lock the car, and then unlock either a door or boot with the actual key
Why do you want to set the alarm off anyway? Just to test it works or do you suspect it isn't working?
done all of the above alarm goes off when you open door but when you wave your hand around through a open window it doesnt checked the door to see if you can open from the inside and you cant anyone know where the sensor is to sir if its working or if its disconnected in any other way. :D :D
