How Do I Change Turn Signal Bulb On Es300 1996
mew
Well, first of all, are you talking about the front or rear turn signal?
FRONT: Unbolt the headlight assembly, and near the turn signal area, there will be a little white "knob" that you unscrew and pop out. That has a little orange bulb on it. You just remove it and replace it.
REAR: Unbolt the tail light assembly and near the turn signal area, you will see the bulb "knob" again. There are many different bulbs back there, so make sure you are replacing the correct one.
THAT SIMPLE..... :)
