1993 Ls400 Series 2 Problems
Dear all,
as a recently new owner (1 month) of said LS400 I am currently experiencing one or two problems and am hoping some kind soul out there may be able to help/advise.
1. Err message (no number) when try to use CD. The unit will recognise which trays I place CD's in but will not read the tracks or play! Is this repairable or is it fix with a replacement. If so any ideas where from and price. I have tried the ususal e-Bay and AutoTrader and had one quote from a breaker supplies of £249.00 for a replacement with only 30 days warranty!
2. Speedo needle illumination starting to fade from outer tip. In low light I can see the illumination trying to recover but so far (1 week ago) nothing doing.
Other than the above I am, so far, very please with the car and hope to continue to be so.
Any help/advice would be most gratefully recieved.
Cheers,
Paul
Hi Paul and welcome to LOC
My tacho needle has been 50% black for 3 years now, I just ignore it! It started off by flashing but soon just died. Aparently its to do with the fact the the needles are high voltage fluorescent tubes (my words - cant think of another way to describe them!). Lexus want LOADS to put them right, Chris Vince may be along later with a suggestion.
Ensure CD's are in up the right way - labels underneath - other than that, try a cleaner CD - otherwise a breakers may help with another unit - I dont know of a direct replacement. Mine works most of the time, just occasionally will hiccup for a while, then return to full working order.
HTH
Dave
HTH
Dave
Hi Dave,
thanks for the swift response.
I'll take your advice on the tacho needles - who needs to know the speed anyhow! Seriously though, I'll leave them a while and see what happens.
I am keen to sort out the CD changer so a friend (former Lexus Dealer Service Manager so he should know what he is doing) has offered to remove it from the boot and give it a look over - I'll keep you posted on progress.
Thanks for now
Paul
