Aristo Standard Radio / Amp / Speakers
the_wiley
I have had the Aristo MK1 for nearly 2 months now & am itching to change the Radio as the CD player jumps a lot, also the sound quality is not too cracking. Will the headunit out of a MK2 be compatible with the amp or not ? Also has anyone changed the speakers ? if so what size are they. Also has anyone changed the 12" sub in the rear shelf as I think mine has perished as I managed to put my finger through the flexi part around the outside.
ThE_WiLeY
I'd say no to a mk2 headunit, the mk1 aristo stereo loom is a nightmare....
I posted up a connector diagram somewhere which may help you....will try to find it.
Ahh here it is http://www.lexusownersclub.co.uk/forum/ind...c=31559&hl=
Better off getting an aftermarket amp (i picked up one for £10 off ebay) and doing the lot. :)
