Lexus Is200 - Fog Light
Bit of a PITA this one:
You'll need to jack the car and remove the front wheel to allow access to the wheel arch liner. Pop out the studs which secure the front of the liner and peel it back to allow access to the back of the fog light. You can then remove and change the bulb.
thought as much, i was hoping there was an easier way - need to get a repair manual for the car too, like the haynes manuals - any idea where i could get one from - dont even mind if its in pdf format
Haynes dont do one :o i think you can get from lexus but cost ££££££s to buy :blink:
the way i have always done it is by just removing the bolts on the side of the fog light that holds it too the bumper and pull it out, replace the bulb and put back... simple :D
Yeah, and that's fine if you have one of the models (earlier ones, I beleive) where they are accessible from the front........
