Bleeding Brakes
jay m
just bought my new brakes and pads and after fitting the front set i realised they need bled. from my low knowlege of cars i dont know what order to bleed them, on my last car it was starting at the front right and then working anti-clockwise around the car, is this the case with my is200?
any help much appreciated, thanks.
jay
Did u have to clamp down the pistons on the calipers?
If so i would give them a quick bleed, doesn't take more than 15mins!
Nope the pad went in ok after wards gave the pedal a few pump and all was ok might do it and upgrade the brake lins at the same time
