Clutch Change
1sTee
hi lexus lubbers.
my clutch is going to need changing soon. just wondering what i can expect to pay either by getting it done by lexus/toyota or a third party garage. and is it better to go the lexus/toyota garage route?
the cost aint the issue, its the rip off factor that bugs me.
hi lexus lubbers.
About £150 for a clutch and about the same for fitting- thats not a Lex one either - but probably as good.
When I had my IS200, the clutch started slipping after a standing start against my mates 911. I lost !
Any way I almost changed it, but then it stopped slipping for a while, until another mad standing start.
But then it stopped slipping again - it started again quite often, but that was probably a year later.
It juddered a lot on up hill starts, which if you search other posts, is quite common.
  • 1 month later...
hi lexus lubbers.
You may need a new flywheel also and dont hold yr breath its exactly £691 + VAT from Lexus (Reading) they quoted me that yesterday!
You may need to get it skimmed also which would be cheaper!
Or get one from Pro Lex £285 or 2nd hand which will be much cheaper!
Tell me how you get on!!
