Sign in to follow this
Russdx
Removing The Cd Changer From A Is200
hi i just bought a is200 and getting error5 with means the cd mech is f***ed how do i go about removing the cd player from the car so i can either mend it or just put in my normal panasoic
thank you :)
Edited by johnboy1
Without satnav?............lift up felt padding revealing 4 bolts,then take hold of the seat heater switches the ones with the t/control snow con buttons.....grip tightly and give a sharp tug pulling towards you revealing another couple of bolts.....careful when pulling the whole unit out as you can if not careful scratch the dash.
hi russdx, welcome to loc.
what part of bristol are you from
i'm not far away
backwell dude on a370 bout 5min from centre
sweeet ripped tht thing out its f***ed lol just ordered the Stereo fascia for car tho just need to find the cable tho not haivng much luck tho
Edited by johnboy1
see you found a wiring harness,keep us informed with your
results,good luck :D
yeah dude said standard toyota 1 works on s model so ordered 1 of them hopefully it works lol
will keep u updated :)
if the SE or sport, just place your hand under the heated seat switches and pull out.
there are two bolts there (10mm I think)
lift up the felt mat on the top and there is two bolts (10mm I think)
give the air blower and top section a good tug to free it.
you should be left with the heater controll section and stereo
Undo the two bolts that are left in the top
NOW TAPE UP THE TWO DASH BOARD EDGES with masking tape, trust me.
now just pull out the stereo and heater controll and unconect the plugs in the rear.
you can now split the heater and stereo
like magic! :hocus-pokus:
Craig
On the older models, you can't lift up the felt. Just tug the whole section, holding it by the top of the air vent, forward. You'll see the felt is screwed on from underneath.
