Rs200 Altezza Wiring Loom
IRLRs200
Hey guys im sure this question has been asked before but used the search function couldn't find accurate results. Basically i need the Iso connector block to connect an after market headunit to the factory connections. Mine is the amplified factory system so i can just use the standard toyota ISO wiring loom, it doesnt fit. Does anyone know where i can get one online? I tried about 10 different audio and motor factors in Dublin, none of them had a clue. The PC2-17-4m one doesnt fit.
Sorry for asking a question thats probably been covered ten times over, I just need to get the music flowing in thge car again asap! :D
yep the amp has to go
you will then use the wires that were connected to the amp to connect to the head unit
So if i take the speaker connections out of the amp altogether and stick them into the headunit connections? im clueless about this and no one in ireland will rewire anything for me cause its an import
