Sub's
you can do this but you need to change the line input to the amp...i dont think the Standard IS stereo has phono output plugs so you will need to take speaker signals to the amp, if you amp only takes phono connectors then you will need to buy a little box that converts from speaker signal to the phono type...
my mate did it like this with his Pug 106 using the standard stereo...worked quite well too.
there may be more on this in the stereo/ICE section on the site.
Aaron
