Noise In The Engine Bay
Greg_P
Hi Guys,
Im looking for a bit of advice here. I have the 3G-SE engine in my tezza and recently a little "Squeek" noise has started to come from the engine bay. Im pretty sure its got to do with the timing belts, or at least coming from the wheel the belts are mounted on.
If I zap it with WD-40 does anyone think this will be an error ?
Should I be concerned ?
Would say that it sounds like the drive belts rather than the timing belt.
DON'T SPRAY WITH WD40 it will just make the belts slip, check the tension on both belts and adjust as required.
Oh and I would say nothing to worry about
Edited by MacRS200
yeah it does go away after a good run, its just that its crept in recently.
I used to have a hilux in south africa which did the same thing and that was due to a bit of corrosion so I was nervous that it could be that, but thinking about it the belts sound more likely.
for fast solution to eliminate the squeking sound from the belt, try to apply some wax to the belt....... cheapest and easiest way is to apply a candle towards the belt while its running...... but be careful..... it will eliminate the noise completely...... but for temporary...... heheheh
