'knocking'
mackdaddy
Hi guys,
Had a knocking noise coming from the front wheels when braking and turning at the same time a little while back. :angry: I changed the front pads for Mintex ones and the knocking stopped. :D Been on there about 2 months now and the noise is slowly coming back, not as loud but definately there. :crybaby:
Any Ideas??
Cheers
Chris
:D
take it your aware of the previous posts on this? that its probably the pads moving in the calipers and a temp fix is copper grease between the pad and caliper, hence your noise is now back?
mine does the same and a fews others do too its been noted as an annoyence, however there is more under there that can make this noise eg bushes etc...
Aaron
