Induction Box Fitted
IRLRs200
Heres it without the box:
And with:
Hard enough to install, you actually have to use the mounting bars that come with the induction box not the induction kit. Make sure you use the 2 washers provided to secure the top part. Make sure the spring washer is put closest to the head of the screw. If you dont the screws will vibrate out when you drive! I lost one like this! Also it scratches very easily!
Looks nice .... but where is the majority of cold air now entering that box?..... from the hole on the wing?
Yup, thats the idea :)
Its not designed to 'bring in more air' Its main purpose is to reduce ambient temp if the air intaked.
TBH, this isn't actually a huge problem on the 3S-GEs, the hottest part, Manifold, is on the otherside of the engine :lol:
