Clutch Squeek
Hello bit of a strange one i have noticed that when i press
the clutch pedal down there is a Squeeking noise (& no its not a mouse)
at first i thought it might be the spring on the pedal, but the noise is
coming from under the car.
Any ideas before i take it to a garage to get clutch checked out
is there any moving parts that i might be able to Grease from underneath
as all i can see in engine bay is the clutch master cylinder
i have tried the test to see if clutch slipping( put it in to third gear and accelerate) but seems fine.
Any help appreciated
Matt
mine has the same noise, on here and local garage said its the clutch release bearing and nothing to worry about although it is annoying. Get it checked out if/when the time comes to change the clutch
I also have the same problem but it seems to be intermittent :question: maybe i just have the stereo to loud to notice it anymore :D i'm due a service next month ill let you know the outcome hopfully it is just the release bearing, if anyone has a service before me I would appreciate any info on the outcome relating to squeeky clutch syndrome
