Hi guys,
Searching the site, I have read lots of confusing stuff, so I thought I'd seek clarification. I have a '98 LS400, and one of the low beam lights has failed. Does the 98 use regular HB4 9006 bulbs, or does it have the mega-expensive, supposedly ever-lasting HID ones?
I want to order the replacement before dimantling the car (which you need to do to get access). Any tips on removing bulbs also greatly appreciated. Once the Battery and air filter are removed, and the plastic covers over the back of the headlight units removed, do the bulbs just pull out?
Should I replace the other one at the same time, or should it last for a while?
Anything else to be careful of, or any advice?
Many thanks, hope I can get this sorted quickly!
Rob
